12awg will be fine, your not doing long cable runs and you are not running at full power continuously, racing quads pull over 120A in bursts with those connectors. just make sure the connectors are always clean and dry, any dirt or corrosion and then you start having problems.
if you want to run at high power for long periods of time then you could upgrade to a XT90 but I dont think you would need it.
Your battery is 16ah@15c giving you 240A max its more than adequate for what you want do.
That is a relief. But the battery has an EC5 plug connected to a 18 AWG EC5-XT60 cable. Do you think this one needs replacing? I also have a 14AWG splitter. The only other thing the battery is connected to through the splitter, is a low power telemetry device. So I am now mostly worried about the 18 AWG EC5-XT60 cable.
18 is a little thin, if the battery has a EC5 on it just get a EC5 for the pdb and keep the adapter for charging. 14 is still a little thin, the problem with boats is there is zero airflow compared to aircraft, so things will get hot much faster since they have no cooling airflow.
Ahh, I did actually think of that. But I wasn’t sure if it was ok to do it without using “M”. Good to know Then i would just need to get rid of the 18 AWG wire and replace it with a 12 AWG one, right?
Correct, you just need wire and connector to match your battery directly to the PDB without any adapters or splitters. if you need power for anything get it from the Power Distribution Board thats what its there for.
also drawing power before the power module is a bad idea as the current used wont register on the power module on the pdb.
Then I would not need to remove the already soldered cable.
One thing I dont really understand is, the signal wire from ESC is soldered on to the PDB. How does the PDB then transfer the signal over to Pixhawk? I am guessing its from one of these
Im running a couple of T200’s at 20v
i suspect you’ll find you wont be running them at 100% power as your hull will have a sweet spot at a lower speed setting - ie more power doest give more speed.
If you are concerned about power - then build up your speed and power slowly - stopping to feel the wires and connections. Warm is ok - hot is telling you there is a problem.
I put a lot of thought into how to cool the ESC’s - if you are putting in 48Amps - then the heat has to go somewhere - so ideally not in a small air tight box.
Is it possible to tune the speed/power from the ground station? I dont need or want 100% power, but I want to tune it to prevent any accidents. Ive also thought about cooling, but so far not had any good ideas
