How much Commonality is there, as far as peripheral connections, between the APM 2.6 and the Pixhawk? is it a clean swap if i already have APM 2.6 with all the goodies (GPS, telemetry, 3DR Power Module)
does Pixhawk work with Mission Planner, AndroPilot or Droid Planner?
I beg to Differ, Stefan, this is a Support question that asks if a PixHawk is a Clean Swap of an APM 2.6 While using Arducopter 3.1. it was not a technical question, just a product/pre-sales inquiry.
I didn’t say that it’s not a support question in general. I said it’s not a Copter software support question, as you were asking about connections and such. That is hardware and therefore belongs to the hardware support section.
But anyways, all the information you need is in the product description and the documentation of the Pixhawk and the Firmware.
I use MTK3329 GPS which use 5pin connectors. My Pixhawk was not shipped with any 5 to 6pin connectors only 6 to 6 and 4 to 4 pin connectors so I was stuck until I bought another connector.
If you use Ublox they are fitted with 6pin connectors
