[quote=“Leonardthall”]Can you describe how you tuned the copter?
I suspect Autotune isn’t coming up with gains that are too high for your copter, I think the problem is you are flying the copter in a different configuration to the one you used to autotune.
[/quote]
Well, now you tell me! I have been posting about this and even mentioned it to Tridge as I wasn’t sure of the best procedure to use when using a gimbal. I’ve seen other users mention that as well. Sure wish this would have come up earlier as I’ve had two bad crashes and waited weeks for support. Oh well, better late than never I guess.
If you are flying with a large gimbal that is free to move on the frame you will probably find that auto tune doesn’t work. If you do autotune with a load firmly attached to your copter then replace it with a gimbal your parameters will probably be too high and verging on unstable.[/quote]
Well, there you go. I thought the gimbal moving around would cause issues so I replaced the gimbal with a dummy load that doesn’t move around too much. It moves a bit but I thought that would be a good representations. So I did give it a fair amount of thought.
The best approach to using autotune in this situation is to remove the gimbal and do autotune with the lightest setup you can (that doesn’t cause the battery voltage to sag). This should give more conservative pids that will be safer with your gimbal.[/quote]
Well, that’s the info I needed. Thanks. But it certainly doesn’t seem logical. I would have thought that you want the copter in the configuration you will be flying with during tuning which is why I specifically didn’t tune it with the gimbal attached. I hope this info gets documented somewhere where others will see it so they don’t have to learn the hard way as well.
However, the final performance depends on the resonate frequency of the gimbal and suspension system. Autotune is not designed to tune a copter with this extra degree of freedom. In the end you must ensure the copter is stable yourself and make manual adjustments if needed.[/quote]
Good info, thanks. It’s probably a good idea to publish this disclaimer in the documentation don’t you think? How does a person know what a reasonable tune is and what isn’t? The copter flew fine after auto tuning even with the high PIDs. I tested it with dummy load for a week before putting the expensive gear on it. I also tested auto tuning on smaller copters and got great results which gave me a lot of faith in the results it comes up with.
What more can a user do? The issue only showed up after a second event where the copter fell after a mode switch. Of course, the issue seemed like switching modes and not related to tuning. It was only after Craig looked at the logs that things came together. After all, you don’t zip around with a copter like this so the event that showed the issue won’t show up immediately.
I’m very disappointed here. I received little to no help when I reported the first incident. One developer wasn’t interested in teaching me how to figure out the results, and then here I had to validate myself and the situation to get someone from 3DR to look in to it. It was only by accident you came here and provided assistance after I mentioned it on DIYDrones. But users have specifically been asked not to post support requests there.
I’m trying really hard to contribute and to be supportive. But it’s getting harder and harder. Given how much money I’ve spent to do so I’m beginning to wonder why I bother.
But kudos to you. Your code is fantastic and I really appreciate your assistance.
