Survey Mission
I think there maybe a small bug in Mission Planner Survey Grid which asks you to input a flying speed in kmh but when you accept the survey grid it appears as DO_Change_Speed in m/s
David Ardis
the final output should be in m/s, I will need to confirm the conversion is correct.
Still seeing the same error in the lasted update of mission planner when in survey grid 1 it is asking or kph when I enter 26kph i would expect DO_Change_Speed to say 8 m/s instead it reads 26.
Is there a problem with my version of mission planner.
Thanks
David Ardis
