Hi there,
I use Survey Grid quite a lot to fly areas with a drone. In most cases I need to stay away from the polygon lines / stay inside the area drawn as a polyon.
Is there any way to use a negative value for the overshoot command like -10m ?
Something like “undershoot”…
At the moment I have two options: Make the poligon smaller or create the waypoints and move each of them manually some meters inside the polygon. Both is a bit boring to do and take a look of time.
Thank you for any tipps about this.
Bye Manuk
