I have been having problems with the % overlap and sidelap when taking picture of crops. I would set the values to like 75% and would end up getting like 25%. I decided to check the Mission Planner calculation and found a bug. Here is the issue…
Settings
AGL = 300 ft
Focal Length = 5.5 mm
Sensor Width = 4.8 mm
Sensor Height = 3.6 mm
Mission Planner calculates
Field of View Horizontal = 261.8 m
Field of View Vertical = 196.4 m
I calculate the following
Field of View Horizontal = 261.8 ft
Field of View Vertical = 196.4 ft
A big difference in the Field of View calculations …
Has anyone else run into this problem?
