Hi all,
I’am working with surface tracking but, I developped a drone only for indoor flight and I’d like to do a surface tracking but with the ceiling so a ceiling tracking :).
I’ve read the source code specially surface_tracking.cpp and Copter.h, whant I understand is in the code you use
Surface::GROUND
And I’ve seen Surface::CEILING
, so my question is if I changeSurface::GROUND
by Surface::CEILING
is it working? Beceause for now surface:ceiling is only to avoid to beat the ceiling is it right?
Or should I only use set_surface
method to change GROUND to CEILING ?
Edit: in the documentation here I can read for Surface Tracking Up/Down
This three position switch determines if surface tracking via rangefinder is toward the ground (low) or ceiling (high), or disabled, otherwise.
So if I understand well if I set this auxiliary function (75) to 3 positions swith and if the value is high my the surface tracking will be run with ceiling tracking am I right ?
