Support for log analysis
Hello from South of France
I just crashed my easyglider with pixhawk
Fuselage broken, rest is OK
The plane was in FWBA and suddendly went down (I tried a desparate RTL but no chance)
I tried to find the root cause without any success (I suspect a mechanical failure)
Can somebody do a check on the log file (attached)
Thanks in advance
Adolfo
[log crash easyglider]
https://drive.google.com/open?id=1jm8MEGJXREUuenIvVj51WcTr55Py9v2G
Thanks Matt
I put the file under link (hope it works)
Adolfo
@adcam No, we can’t get the file yet. Your link is literally to “my Google Drive” so each of us gets routed to our own google drive. :laughing:
You need to right-click the file inside your Google Drive and use either “+Share” or “Get shareable link” (or something similar.)
I should be ok now
Adolfo
I’m looking at your log, and see some things I haven’t seen before. Take a look at the messages in MSG.Message
You have two separate “events” that give strange messages. Mid-flight, from about 350sec till 370sec, the following messages are logged:
RCInput: decoding UNKNOWN
RCInput: decoding PX4IO_PPM
Throttle failsafe on
Failsafe. Short event on: type=1/reason=3
Flight mode = 1
Throttle failsafe off
Failsafe. Short event off: reason=3
Then, near the end of the flight (455sec to 475sec) a similar group is logged:
Flight mode = 1
I don’t know what causes these or if they have anything to do with the crash.
The plane appears to be in FBWA mode when the sharp terminal descent begins (t=481sec). During the descent it is switched to RTL mode, but that appears to have no effect. That suggests, as you suspected, a mechanical failure. I’m not sure if it helps to keep just looking around randomly… Do you have anything else we should look at, specifically?
Thanks hunt0r
also I found a switch to CIRCLE in the middle of the flight
This is strange :
I have only MANUAL, STABILIZE, FBWA & RTL (i am using Channel 8). When I look the log the Channel 8 is not moving but CIRCLE mode is popping -up
Also I was using FPV @ 1160 Mhz : this could interfere with my graupner (GR16 receiver)
i will do now ground tests with FPV close to GR16 receiver until I reproduce the strange messages
Interesting (despite the crash it is good to learn and improve)
Adolfo
What kind of output is your GR16 configured for ?
I have hundreds of GR16 hours using SUMO12 and SUMO8 , and have never seen decoding issues.
Ardupilot failsafes can make a switch to circle mode. I haven’t had time to look into your log, but CIRCLE mode is definitely possible.
To Andre-K I am using SUMO8
To Naterater
Yes you are right (I believe that it is a basic behaviour when RC signal is lost)
I am trying to reproduce the Failsafe by : FPV antenna closer to GR16, supply voltage noise…
Adolfo
