APM 2.6 FW 3.2 MP 1.3.25
"If Simple Mode is selected the raising the switch high will enable Simple mode, low will disable it.
If Super Simple mode is selected then raising the switch high will enable Super Simple mode, low will disable it and if a 3-position switch is used the middle position will enable regular simple mode."
I now have my CH7 set to Simple Mode and want to change it to Super Simple mode using a 3 way switch so I can have both Super Simple & Simple on the switch. When I go to Extended Tuning in MP
and change CH7 to Super Simple and then save the change I get a warning
"CH7_opt has more then doubled the last input- Are you sure" Is this a problem ? I did not save it yet.
