When I was setting up my quad using APM Planner 2.0 I selected super simple mode when I was assigning flight modes during radio calibration. I would like to go back to normal mode but can’t find out how. The tutorial on Arducopter.com uses Mission Planner for illustrations. They don’t seem to match what I see on APM Planner 2.0.
The option should be located under Initial Set Up screen, then go to flight modes. Once there you should be able un click super simple mode.
Super Simple != Simple (It’s Super )
If you go to the Standard Params view, under Config/Tuning and search for super simple, you will find a drop down option where you can select which modes have super simple enabled.
