Hi everyone. I’m taking a bit of an easy route here, but you guys are the experts so it would be foolish not to ask. I have a cheapo 915 MHz telemetry module (two identical units - one on the drone plugged into TELEM1, and one plugged into my PC for MissionPlanner via USB). Does anybody have any telemetry modules they love so I can get real-time telem info on my MissionPlanner and also send commands? My cheapo one drops out at like 20 feet which is crazy.
I really only need 1km range, and maybe passing through a few light branches, but never BVLOS. I just see this list and don’t really know where to start. If there’s one you like, that’s good enough for me after some follow up research that I’ll do.
Edit: Budget is not a major concern. Low hundreds $ for a reliable system is worth it.
Thank you everyone. In fact the RFD900x was recommended to me, but those seem harder to come by. I’ll check out the ESP32 and the (new) 3DR. These 915 MHz pieces from mRo/3DR seem the most plug and play and are cheap - do you have a specific set you use @Yuri_Rage ?
The ESP32 option also seems good and fun to set up, but that also requires an antenna it looks like, plus an extra DC-DC converter for 3.3 V.
Thanks everyone for lots of comments. I picked up some mRo 915 MHz modules. I will say 1km was an overstatement in my original post - it’s actually more like 200m that I need, but I added a few factors just to overspec. I wish it was easier to find some RFD900 because everyone seems to review very highly but I didn’t have luck easily finding online, plus I’m at the point in my system where every gram counts because the payload is pretty heavy.
I am using ELRS Airport serial communications with Radiomaster BR3 and Bandit 915 MHz Module for base unit. I moved to this configuration from the SiK standard which works ok and is easy to configure and connect but I did not get reliable long distance connections and did not to upgrade to large antennas etc. The current ELRS Airport setup is been very reliable.
I have not tested Mavlink over ELRS as the 915MHz support should be coming very soon on ver. 3.5.2. ELRS Mavlink/RC.
