I noticed that the Initial Parameter Setup utility only reports the parameters where it suggests a change.
This caused me a bit of head scratching today because I got two different results when I ran it two times.
For example, the first time it reported a recommended new value for MOT_THST_HOVER and when I ran it at a later time, this parameter was not on the list of it recommended settings.
At first I thought that maybe I had used a different version of Mission Planer. I finally figured out that if the Initial Parameter Setup utility finds that the recommended setting is already set - it doesn’t report it.
As this utility is designed to help new users, I suggest that the utility report the current and recommend values of all the parameters it checks. That way it will be easier for a new user to keep track of all the important initial parameters.
In addition, the wiki would benefit from listing all the parameters that this utility checks.
