Hello
Subject failsafe. Pixhawk, APM
is the cable from the receiver to FC interrupted fligt the copter last flight mode. the failsafe is not active.
This can be changed in the next version?
or is the fault with me?
If the PIXHAWK is losing the connection with the receiver, you completely lose control, of the drone.
That’s why you have to setup the different fail safe options in the PIXHAWK by using MP.
Here you can define a specific value for your throttle, usually lower then 1000 to activate a transmitter or receiver fail safe.
You can then specify if the drone should RTL, or land, I case this fail will happen during flight.
You can do similar things with power levels, to RTL or Land on Fence Breach, very useful if you lose control and the drone is either climbing above a specific limit, or moving away in a uncontrolled manner…
And they all work like a champ !
