This is a QuadPlane running APM:Plane 3.7.0. I’m trying to transition to fixed-wing. When I switch from QSTABILIZE to FBWA, the forward motor turns on and starts pushing forward, while at the same time the plane starts yawing to the left. Since this is a flying wing, it doesn’t lend itself well to correction. Eventually, with both sticks full right and after a few seconds and close to a 180deg rotation, the yaw slows down and stops. I usually then revert back to QSTABILIZE, no transition.
Is there any reason for the flying wing to yaw in such a way when the forward motor is turned on?
I thought about this some more. Since this is a small flying wing, could this be due to the forward motor (push prop) being slightly misaligned with the longitudinal axis of the plane?
Also when switching from QSTABILIZE from FBWA, I had noticed my aircraft was losing a few meters of altitude for a few seconds when the forward motor fires up, and here’s what I see in the logs
Was your flying wing set up initially with APM Plane without a QuadPlane? In other words, did you initially fly the wing using APM Plane “Manual” mode, set the trims and record in TRIM_AUTO before flying with FBWA?
I have found it easiest to set up the plane with APM first and then convert to a QuadPlane.
