Stream Video from Raspberry Pi with OpenCV
I am trying to stream my Raspberry Pi camera video modified using OpenCV to the ground station with the following code:
import cv2
import numpy as np
def send():
    cap_send = cv2.VideoCapture(0)
    out_send = cv2.VideoWriter('appsrc ! video/x-raw ! videoconvert ! x264enc ! rtph264pay ! udpsink host=192.168.2.1 port=5600',cv2.CAP_GSTREAMER,0, 30, (1920,1080), True)
    if not cap_send.isOpened():
        print('Error openning in')
        exit(0)
    if not out_send.isOpened():
        print("Error openning out")
    while True:
        ret,frame = cap_send.read()
        if not ret:
            print('empty frame')
            break
        out_send.write(frame)
        print(frame)
        pass
    cap_send.release()
    out_send.release()
send()
However, when QGroundControl automatically detects the stream it shows me a green page with no frames changing the view.
I have verified that the frames are correctly recorded by the OpenCV.
gst-launch-1.0 -v udpsrc port=5600 ! application/x-rtp,media=(string)video,clock-rate=(int)90000,encoding-name=(string)H264,payload=(int)96 ! rtph264depay ! decodebin ! videoconvert ! autovideosink
But still, the result is the when I use the following gstreamer pipeline in the receiving end, yielding the following output.
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01f40028ffe1001f67f40028919b280f0044fc4e02d40404050000030001000003003c8f18319601000668ebec448440, level=(string)4, profile=(string)high-4:4:4
/GstPipeline:pipeline0/GstDecodeBin:decodebin0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01f40028ffe1001f67f40028919b280f0044fc4e02d40404050000030001000003003c8f18319601000668ebec448440, level=(string)4, profile=(string)high-4:4:4
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01f40028ffe1001f67f40028919b280f0044fc4e02d40404050000030001000003003c8f18319601000668ebec448440, level=(string)4, profile=(string)high-4:4:4
Redistribute latency...
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01f40028ffe1001f67f40028919b280f0044fc4e02d40404050000030001000003003c8f18319601000668ebec448440, level=(string)4, profile=(string)high-4:4:4, pixel-aspect-ratio=(fraction)1/1, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, coded-picture-structure=(string)frame, chroma-format=(string)4:4:4, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, colorimetry=(string)bt709, parsed=(boolean)true
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/avdec_h264:avdec_h264-0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01f40028ffe1001f67f40028919b280f0044fc4e02d40404050000030001000003003c8f18319601000668ebec448440, level=(string)4, profile=(string)high-4:4:4, pixel-aspect-ratio=(fraction)1/1, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, coded-picture-structure=(string)frame, chroma-format=(string)4:4:4, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, colorimetry=(string)bt709, parsed=(boolean)true
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01f40028ffe1001f67f40028919b280f0044fc4e02d40404050000030001000003003c8f18319601000668ebec448440, level=(string)4, profile=(string)high-4:4:4, pixel-aspect-ratio=(fraction)1/1, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, coded-picture-structure=(string)frame, chroma-format=(string)4:4:4, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, colorimetry=(string)bt709, parsed=(boolean)true
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01f40028ffe1001f67f40028919b280f0044fc4e02d40404050000030001000003003c8f18319601000668ebec448440, level=(string)4, profile=(string)high-4:4:4, pixel-aspect-ratio=(fraction)1/1, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, coded-picture-structure=(string)frame, chroma-format=(string)4:4:4, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, colorimetry=(string)bt709, parsed=(boolean)true
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstH264Parse:h264parse0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01f40028ffe1001f67f40028919b280f0044fc4e02d40404050000030001000003003c8f18319601000668ebec448440, level=(string)4, profile=(string)high-4:4:4
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01f40028ffe1001f67f40028919b280f0044fc4e02d40404050000030001000003003c8f18319601000668ebec448440, level=(string)4, profile=(string)high-4:4:4
/GstPipeline:pipeline0/GstDecodeBin:decodebin0.GstGhostPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01f40028ffe1001f67f40028919b280f0044fc4e02d40404050000030001000003003c8f18319601000668ebec448440, level=(string)4, profile=(string)high-4:4:4
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/avdec_h264:avdec_h264-0.GstPad:src: caps = video/x-raw, format=(string)Y444, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, format=(string)YV12, colorimetry=(string)bt709
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0.GstGhostPad:sink.GstProxyPad:proxypad1: caps = video/x-raw, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, format=(string)YV12, colorimetry=(string)bt709
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstXvImageSink:autovideosink0-actual-sink-xvimage.GstPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, format=(string)YV12, colorimetry=(string)bt709
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0.GstGhostPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, format=(string)YV12, colorimetry=(string)bt709
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:sink: caps = video/x-raw, format=(string)Y444, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstDecodeBin:decodebin0.GstDecodePad:src_0.GstProxyPad:proxypad2: caps = video/x-raw, format=(string)Y444, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)30/1
WARNING: from element /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstXvImageSink:autovideosink0-actual-sink-xvimage: Pipeline construction is invalid, please add queues.
Additional debug info:
../gstreamer/subprojects/gstreamer/libs/gst/base/gstbasesink.c(1249): gst_base_sink_query_latency (): /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstXvImageSink:autovideosink0-actual-sink-xvimage:
Not enough buffering available for  the processing deadline of 0:00:00.015000000, add enough queues to buffer  0:00:00.015000000 additional data. Shortening processing latency to 0:00:00.000000000.
ERROR: from element /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstXvImageSink:autovideosink0-actual-sink-xvimage: Output window was closed
../gstreamer/subprojects/gst-plugins-base/sys/xvimage/xvimagesink.c(586): gst_xv_image_sink_handle_xevents (): /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstXvImageSink:autovideosink0-actual-sink-xvimage
Execution ended after 0:00:13.277670659
Setting pipeline to NULL ...
Freeing pipeline ...
