hello a question due to lack of space in a boat if I stick the here 2 gps antenna on the cube, could that be a problem?
Interference might be a problem, but you can only know if you test it.
I would be worried about that causing extra vibration. Maybe make a frame that goes over the cube without touching it, and attach the GPS mast to that.
