Steering issue with two servos and one channel
I’m building a crawler and after some problems now is working in manual mode.
the problem is steering in front and back wheels. I connected the front steering servo to pixhawk port , but how could I do to steer the back wheels like the picture?
thank’s all
Eduard
I do not know if it is possible to program the controller to have a second steering output with reverse output.
Hardware approach would be to purchase a servo reverser circuit. Do a search for “server reverser” - plenty out there. Will also need a ‘Y’ servo splitter cable if the servo reverser does not have a straight through output for the front steering servo.
Eduard,
I think you should be able to set another output channel to use function 26 (i.e. SERVO2_FUNCTION = 26) and it should work. I have not specifically checked this but it should work and if it doesn’t we can fix it.
Hi @rmackay9
Thank’s for your help. The problem is I did not have free channels in my receiver. Or Did you suggest to connect the servo to pixhawk cannel 2 output?
Thank’s
hI @rmackay9
It works !!!
thank’s
Eduard
excellent! Glad to hear this worked!
