STB_PIT_P / RLL_P value 0
https://www.youtube.com/watch?v=Fc-ZF6oWQNs
You can see in video, as soon i press refresh button, all values goes to 0. I tried to flash it again, tried load defoult settings . did not helped.
Any options ?
Your video name is AMP 2.6, does this mean you are trying to use Copter 3.4 in an APM board? Because APM boards aren’t supported since 3.3…
I used 3.3.3 same thing
3.2.1 is the last firm for APM i hope.
well i figured out the problem. and AMP flying like a charm.
close this thread
Yes, it’s because the Ch6 tuning is being used so that’s overwriting whatever you type into the field. Anyway, glad you figured it out.
