The mavlink message ‘STATUSTEXT- 253’ has 50 characters limit.
is there any way to increase this limit? I am trying to send some custom messages from CC to my GCS.
any help would be appreciated thanks.
thank you for reply. But as I understand you can only send ‘float’ values to the other side with NAMED_VALUE_FLOAT
I want to send the ‘text’ or characters that are above 80-100
Hii @scarletwitch …
Did you find how to send more that 50 characters data using status text??
Why didn’t you read the message’s specification ?
https://mavlink.io/en/messages/common.html#STATUSTEXT
Use the id and chunk_seq fields to send a sequence of messages that can then be reassembled at the receiving end.
hello not yet,
i went ahead with current standard mavlink message and I am sending it in chunks by defining chunk_id.
let me know if you also find any solutions around this.
