The status window under flight data is went missing when I updated to 1.3.0. I found it verry conveniente to have all the parameters showing under one tag.
What happend?
With kind regards,
//Mikael
@hojdan,
I updated to MP 1.3.0 also and I have the status tab, along with all of the other tabs, still below the HUD and when I am connected the APM over MavLink I get parameter status when I click on the status tab.
Regards,
TCIII GM
Thanks for your answer.
What kind of OS are you running?
I’m running Windows Vista.
@hojdan,
I am running MP on an HP laptop using Windows 8.1, but I use the desktop only.
You might see if you are using the latest graphic driver for your display and if not try updating the driver.
Regards,
TCIII GM
