Standard Params Page Empty
I am running the following:
Windows 7 64 Bit
Mission Planner 1.3.74 Build 1.3.7563.27684
3DR Pixhawk PX4 (2014) Running ArduCopter V4.0.7 (0bb18a15) // Was previously running 3.4.5, had not used it for over 4 years, kept in a dry cool environment
I just recently updated my Mission Planner and firmware on my device. However, when I go to the standard params page, there is nothing there, just a blank screen. What should I be doing or trying?
Windows 7…hmmm time to upgrade. It could be a windows issue.
Are you connected to your FC to see the parameter list?
Don’t disagree on the Windows Update. However, everything is able to connect and no issues with that. However, when I go to config and then standard parameters, the page is just blank.
Works OK for me , but really I never use that page. Sometimes I looks at “Extended Tuning” but 99% of the time I go straight to “Full Parameter Tree”
Maybe try newest Visual C++ redistrib…
or do the MissionPlanner driver clean, uninstall and new install.
do you still have 3.4.5 on it? if you do you need a newer fw. at a guess the param names have changed so it wont work with the old version
No. In my original post I upgraded the firmware to the latest:
