We use copter 3.5.5 for our hexa-rotors UAV.
The Vibration is in good level in stabilize mode. but changed worse in Loiter mode with forward flight.
Can anyone help?
the bin file is as follow:
https://drive.google.com/open?id=1C6132u1E64skSc9PigH2fo_lYiGeA2xO
https://drive.google.com/open?id=1Ib5Hd0XNB1VGVziVhc8i_GbKc2HofaWr
Did you balanced props, checked bad bearings and loose components, cables onboard ?
Yes, we did, we also arranged the cable in C shape to avoid magnitude interference.
We didn’t use vibration isolation for autopilot. we tried damping materials, the vibration level was getting worse.
Are you the same guy on RCG with the hex that has the middle arms WAY longer than the other 4 arms?
Yes, the middle arms are longer than the other 4 arms.
