This is my first drone so I am still trying to figure everything out. I read on http://ardupilot.org/copter/docs/flight-modes.html that it is good to practice in Stabilize mode first, and move on from there. The controller that switches between GPS and Indoor according to tower is switching between Loiter(gps) and AltHold(indoor).
So i mapped stabilize mode to the controller through the web interface but when I switch over to stabilize I get “Throttle too high” and cannot arm the drone. The gps light starts blinking on the controller when i switch to stabilize too. Not sure if that matters at all. Anyone have an idea of what is going wrong here?
You need to move the throttle to bottom right to arm in stabilize.It will not arm with the throttle at half way.It doesn’t use the GPS.It’s just you and a bit of stabilization controlling the copter.No hands off moments in stabilize.
