I would like to find out if it is possible to split a Survey Grid Mission that you have created in to separate missions.
What I mean is, that if the Mission is to long for 1 flight then you can split it in to different Missions without having to go and draw the Polygons over.
I save the mission using another name, like AM1 and AM2.
For AM1 I delete the last half of the waypoints and save it.
For AM2 I delete the first half of the waypoints.
It helps if you make the end and start points between AM1 and AM2 close to Home.
