I did a new installation of the latest (v 1.3.28) MP on a PC and SPLINE_WAYPOINT isn’t listed in the command drop down list. Further, if I check the Spline box before clicking on the map, it drops a waypoint at 0,0 Lat/Long.
The first installation was on a Windows 7 machine. I subsequently tried it on another 7, then on a Windows 10 technical preview PC. They all behave the same.
This only seems to happen on fresh installations. I use two Windows 7 laptops for flying and they were both updated from previous versions and work fine.
Wondering if anyone else has encountered this or has a solution.
Apparently nothing is wrong with it. It’s default for airplane mode which doesn’t have spline waypoints. I found that by opening a telemetry log of the appropriate aircraft, it switches mode. It takes on whatever mode the flight controller is in of course, but I didn’t think to do that.
I downloaded flight logs from droneshare.com and was able to switch it between airplane and multicopter modes.
