Spinner won't Stop even sprayer pump was off
@rmackay9
I have testing AC 4.3.7 for agriculture drone and found that spinner won’t stop even sprayer pump was set low ( pump was off).
This is my setup
Servox_ Function = sprayer pump(22)
Servox_ Function = sprayer spinner (23)
Rcx_ function = 15 ( spray pump)
Spary enable= 1
Spray_ Spinner= 1300.
When i start pump using RC switch spinner also starts rotate but whereas when i switch off the pump spinner doesn’t stop and keep running at constant speed until reboot the drone completely. How to stop spinner when pump aslo stops?
Hi @rmackay9
Can you suggest with parameters how to switch of spinner when pump also get off!
please supply a whole parameter list as a file.
Thank you @xfacta i will provide parameter file tomorrow.
DH-AH-E10 0033 PARAM.param (18.1 KB)
here is the log file
I see these related parameters:
RC8_OPTION,15 // sprayer on/off pilot control
SERVO9_FUNCTION,22  //  pump
SERVO9_MAX,1900
SERVO9_MIN,1100
SERVO9_REVERSED,0
SERVO9_TRIM,1500
SERVO11_FUNCTION,23  //  spinner
SERVO11_MAX,1900
SERVO11_MIN,1100
SERVO11_REVERSED,0
SERVO11_TRIM,1500
SPRAY_ENABLE,1
SPRAY_PUMP_MIN,0
SPRAY_PUMP_RATE,40
SPRAY_SPEED_MIN,1
SPRAY_SPINNER,1500
I would try setting
SERVO11_TRIM,1100
or lower, to 1000, to see if that makes the spinner turn off when the pump is not active. I think it will be defaulting to the TRIM PWM value when not actively set to something else.
Thanks @xfacta spinner stopped when pump also switch off.
Servo11_TRIM = 1000
