You should connect a satellite only to the Spkt port. Connecting a bigger receiver likely won’t work. There are some timing issues in AP 4.0.x which are likely resolved in 4.1.
My recommendation is that you buy an SRXL2 receiver and use that with AP 4.1 - I am using these with great success and they have full telemetry.
Ok, thanks, I will try with this one.
However, I have seen that the cable to the SRXL2 is a 4-pins cable. Then, you need to create a custom cable to connect to Pixhawk Cube black ? (Spkt port is only 3-pins) I’ve seen that a pin of the receiver is unused, so there should not have any problem doing this.
Ok, thanks.
On pixhawk cube, telem port are 6-pins., so I need to create a custom cable, right ? Which autopilot are you using ?
What about flight parameters ? Which one did you have to change to make this work ?
