@geofrancis Yes wiring is no issue for me. I could make a small breakout board and add power from an ESC with BEC.
I really just wanted to be sure if there were any hardware limitations that would prevent the V3 to be used on a Plane.
Is it possible to set the FC as to be similar as the Spectrum SAFE/AX3 system? Like a beginner mode that limits roll and pitch angles? (seem like this is FBWA/FBWB)
It’s not really designed for that, once the plane is set up it’s as good as the safe system in FBW-A and with FBW-B and minimum altitude set you can’t crash it even if you tried. I have let random people, and children fly my planes in FBW-B since they were just steering the autopilot and is basically an RC car in the sky.
If you have never flown RC planes I would really recommend getting some simulator time, so if it’s really badly tuned on your first flight then you have a chance of landing it manually in once piece.
