I want to run VTOL on Speedy Bee F405 wing , but i have a issue, After I set the data, the tilting servo does not work and displays zero at servo CH 5 and 6. When I switch to CH 9 and 10, it can work, but at this time the turn motor does not work, and the motor display at the ground station It was normal, but the ESC could not receive any signal, and after I updated to the latest version(6/7/2023), the motor finally worked normally, but this time it was the turn of the tilting servo to not work, and the CH5 and 6 also showed zero, but now Going to any CH for the first time is the same problem and doesn’t work. I have the same settings on Matek F405 wing and it works fine.
