I made a first drone with a pixhawk 2.4.8 and a power module as controller
following an engine problem that had misfires my drone crashed.
I thought of an engine or esc problem so I changed the 2!
but no because after reassembling it, I have the same problem again:
an engine runs slower sometimes stops or slows down
it turns out that the pixhawk is sending a bad signal on output 4
because by changing the order of the servo the concern moves
I tried to change the output but it’s the same thing
so need help to understand
is this a power problem?
by pixhawk?
the problem appeared on version 3 and continues on version 4 of copter
