Hi all
I am new to Q GroundControl and running it off my iPad mini. When flight planning in survey mode, is there a set speed control for Survey missions?
Many thanks,
Rory
Hi all
Many thanks,
Rory
If you want to run a survey at something other than the default vehicle flight speed. You need to change it prior to the Survey. You can do this from Mission Start. Or you can add your own change speed command.
