This is a video demonstration from Soubhi Hadri of an AI based gesture recognition system that can be used to control an ArduPilot multicopter (in this case it is a simulated quadcopter).
The system is open source so if you want to look further into how it’s done:
The system is tested with CPU and works in real-time.
What CPUs has this been tested on? Will this run on the likes of a raspberry, or does it need Intel-like power to run? I’m referring to inference obviously, not training.
Thank you! I tested it on 2.7 GHz Intel Core i5. I believe it should work but have not had the chance to run in on raspberry. I think the number of frames per sec will be less but still have the real-time behaviour. If you have the chance to test it, let me know
P.S. to load the model, it needs 2-3sec but you do that just once when you run the application.
