think it should be easy:
-need to know how the camera detects “open/closed” -> set that to open.
-build a circut that converts the (high) voltage of the flash to something usefull for the trigger pin.
If similar to the A5000 then there is a magnet on the side of the pop up part of the flash but the problem is the camera limits the shutter speed when the flash is active.
