Hoping for some steer here: I seem to be hitting a limit in the maximum commanded bank angle/turn radius and trying to understand what’s going on. I am running 3.8.3 in a Discovery/Sensei trainer and I have done lot’s of autotune, etc. On my most recent outing to the flying field, I was trying to set a smaller WP_LOITER_RAD to keep the aircraft withing the bounds of the field. However, even with a setting of 30m, the aircraft is circling with a radius of around 90m.
I also noticed that in FBWA mode, the turns are very wide. I have set LIM_ROLL_CD to 6,000 (60 degrees) but the aircraft seems to be doing much shallower turns.
Any thoughts?
Related question: does WP_RADIUS over-ride WP_LOITER_RAD? In other words, if the latter is higher (say 90m), would that determine the Loiter radius I am seeing, even though the former is much lower?
An autopilot log file would be most helpful. Are you at a high altitude? By default the loiter radius of the aircraft is scaled with the altitude the aircraft is flying at, to reduce stress to the airframe.
I agree that logs would be the most useful. In my experience it has been due to the stall prevention code so you may need to increase airspeed or reduce ARSPD_FBW_MIN. That’s only an initial guess though.
Thanks for your replies, guys. @WickedShell, regarding elevation/altitude, I can confirm the flying location is only just above sea level, so we can rule that out.
I did some more tests yesterday, with NAVL1_PERIOD reduced down to 10, but this does not seem to have made any difference. The bank angle in FBWA, Loiter modes and Auto modes is very shallow - I would say less than 25 degrees, despite 60 degrees for LIM_ROLL_CD. The loiter circles are about 60m in radius, despite WP_LOITER_RAD being set to 30m. I’m really stumped with this!
Hi Nathan, just to confirm that ARSPD_FBW_MIN and TRIM_ARSPD (10 and 12m/s respectively) are fairly high for this lightly loaded aircraft, well above the stall point.
Problem solved, with input from Dr Tridge himself, on the Facebook forum!
It was a combination of 2 things:
Firstly, long tubes for airspeed sensor, which are giving me unreliable readings (ARSPD_RATIO is 1.06).
Secondly, STALL_PREVENTION is enabled, and this will be even more conservative due to unreliable airspeed readings.
Philip Rowse said I can go to 45cm on I2C cables (if they are clear of other cables, etc), so I will locate the airspeed sensor closer to the pitot to allow me to shorten the tubes.
