[SOLVED] Hey everyone. I want to run the QuikTune Lua script on my Pixhawk 4. It is the only script in the APM/scripts folder, and it is only 20 KB. My SCR_HEAP_SIZE is 104KB so that is more than enough (besides, I set SCR_HEAP_SIZE to the maximum allowable under freemem = 191056 and that didn’t help either), so I think the issue is actually something else. In other words, all indications are that I do have the memory. Anyone seen this or know how to clear the PreArm check? Thanks!
Edit: Fun fact, if scripting is enabled at all then I get the PreArm: Scripting: Out of memory fail. I even took the Quiktune script off the SD card.
