[SOLVED] Hi. I want to run the QuikTune Lua script on my Cube Orange Plus but I have the “Scripting: Out of Memory” problem. Please, can any of you help me with the proper SCR_HEAP_SIZE value? Thanks a lot.
Best regards.
I think the default is around 102400 and should work fine. The old default was smaller, so if you’ve been updating over time, the older default may have persisted across version numbers.
Thanks Yuri! I found that the number 204800 is OK. Now it is working the script! Thank you very much for your help!
