Due to the cable routing on my plane I need to mount my compass backwards on the tail. Incorporating the already known Roll180 configuration of the compass, i also need a Yaw180 configuration.
Something like Roll180Yaw180 or Pitch180 (which I believe is the same thing).
However, I can not find such a configuration for compass orentation. Is there something I am missing? Surely mounting the compass backwards isn’t as weird as the many other alternatives which are supported.
@Remi Is this one of the compass/GPS units and are you trying to mount it upside down? (Just trying to make sure I understand the orientation you are looking for).
This is a compass/GPS unit, yes. And I am not trying to mount is upside down. But a lot of these units have the compass mounted upside down inside the unit (such as the 3DR compass/GPS module), which make is necessary to use the Roll180 configuration. Therefore, there should be a lot of options that is combined with the Roll180.
