I am trying to connect my 6 ESCs (newest BlueJay Version, LittleBee ESCs) with my H743 board, iam using the following settings:
- bdshot firmware
- bdshot enabled for S1-S4 (as far as i understand only 4 ports are supported?)
- 6 Motors configured from S1-S6
- Parameter List
- ESC Protocol is DSHOT600
The problem is:
- only S1-S4 spin up with motor test
- Switching the port helps, so i verified that the problem lies within the S5 and S6 ports
- all ESCs are working correctly
What i checked:
- Increasing throttle % and test time does not help
- I tried some different parameters from the web, but this does not help
What am I missing here? Also I am unsure if the H743 has a IOMCU(?), so should i enable bdshot on S1-S6 instead?
Thanks in advance!
