[solved] How to relate RCIN2 and RCIN4 to GroundSteering and Throttle?
HI,
First time user of ArduPilot (Rover). Just set up two flightcontrollers (SpeedyBee Wing and Wing Mini) with ArduRover, connected my PPM-based receiver and did some basic setup;
  • Channel #2 RCIN2
  • Channel #4 RCIN4
As these have always been used/mapped like this on a stick radio for my cars, and also use this with by MT12. This all works…
… but the issue is that RCIN2 and RCIN4 have no relation with GroundSteering and Throttle. How can this be mapped?
Looking into:
What you are looking for is probably this: RC Input Channel Mapping (RCMAP) — Rover documentation
If I understand correctly, in the end you want to set
also RCMAP_PITCH and RCMAP_YAW can be whatever you want but not 2 or 4
Thanks. Will try this out after charging the batteries again.
This also means I can use GroundSteering and Throttle in the Servo Outputs?
Yes.
RCMAP tells ArduRover what inputs are steering and throttle, SERVOx_FUNCTION maps steering and throttle to the servo outputs.
Solved, but unable to change the title to reflect this.
I got you covered :+1:t2:
