I have been searching everywhere for info on using the Sololink IMX6 board from the 3DR Solo with the Pixhawk Black Cube and cannot find much of anything.
I am hoping to use Sololink and the Solo controller (Artoo) from a crashed Solo with my 4wd rover project. It seems like a waste to have it and not use it. It also seems like a fairly decent companion computer for stuff like ROS, OpenCV, etc.
I have the original Mavlink telemetry from APM 2.6 as well as a Wifi telemetry board and ESP8266 available, but I’d really like to have the streaming video.
This is my basic setup:
- Black Cube with mini carrier board
- (4) VESC 4.12 ESCs
- (4) 400w 60v wheel motors
- Solo OEM GPS unit
- Legacy GPS from APM 2.6 package
- (4) 36v to 12v stepdown converters
- (2) APM power module 1.0
- (4) 36v Lipo battery packs
- (2) 60v 12Amp DC-DC step-down converters
- Custom aluminum/composite rover frame
- Solex app on Android
- Solo controller
I’m hoping to make this all work together rather than using an FrSky tx/rx + 5.8ghz fpv tx/rx + Telemetry.
Can this be done? Any tips?
Thanks in advance.
PS: I also need to figure out how to make the VESC ESC hall sensor data from the wheel encoders back to Pixhawk via UAVCAN.
I will also be adding a PX4Flow, proximity sensors, 360 2D LIDAR, a 6dof arm, a sprayer, a Storm32 gimbal and some other stuff once I get the rover put together and running missions.
