I’ve recently been running some tests on a battery conversion for the Solo due to the fading of the stock packs and the need for replacements.I’ve had some success running an 8000mAh pack which has given tests flights of 22 minutes (overflying the capacity a bit).Trouble is when it comes to analysing what’s happening because the logs end half way though the flight.It’s not a brown out as Solo keeps on flying but I’ve heard mention that the low voltage alarm may lead to logging stopping.I’m obviously pushing it way below the stock battery using Multisag packs and I’m guessing it’s a hard coded hardware alarm ? Anyone shed some light on this subject and how it can be defeated in battle ? Thanks. Oops.Open Solo ,AC3.5.4, Green cube.
