Which program do I need to open the log file?
Is Sam Tabor the developer of the function?
I found it.
Mission planer open the bin file.
Yes, Sam Tabor is the developer of the soaring-functions.
See that threat above: Soaring/Gliding for Planes
Thanks, Willy.
I’m looking forward to trying it out.
I’m going to equip the ASW 28 with the Pixracer.
The shipment should arrive this week
Which software should I better take.
The Mission planner or QGroundcontrol?
Thanks for your recommendations.
Hi all,
Hopefully the new changes since last year should be merged into master and appear in a new release soon.
For anyone interested in testing, I’ve built binaries for a few flight controllers here. Let me know if you’re flight controller is missing. Updated documentation should appear on the wiki soon.
All the best
Sam
Thanks for your work.
My Pixracer has been at customs for 3 weeks.
Customs in Germany is massively slow.
Hello, my Pixracer has finally been released from customs^^
I have a question about the configuration.
I imagine the following scenario.
I fly manually by FPV and am in sufficient altitude. Can I now switch on the soaring mode? Does it work? And if so, how do I have to configure it in the parameters?
Thanks for the information and assistance.
Hi Patrick,
as far as I understand the instructions (https://ardupilot.org/plane/docs/soaring.html?highlight=soaring) , you have to activate the soaring function in AUTO, FBWB or CRUISE mode.
Hi all,
The soaring feature has recently been improved for better stability, usability and performance. These changes are now available in the latest builds from within Mission Planner and will be in future beta and stable releases.
I’ve also added a small feature that isn’t in master yet and needs some testing - automatic learning of the glide polar parameters SOAR_POLAR_CD0 and SOAR_POLAR_B during a still air calibration flight. The method seems to work well in simulation and in early flight tests and should make tuning easier on new aircraft.
This only works if you are flying in still air with the new parameter SOAR_POLAR_LEARN set to 1 (set it to 0 again after the calibration flight). It’s still important to set the wing loading parameter SOAR_POLAR_K first by measuring all up weight and looking up the wing area. 5 seconds of data with zero throttle output, steady airspeed target and roll angle below 10 degrees are needed before any learning is done to minimize noise.
The best way to use this is with the RC switch for SOAR_ENABLE_CH in the middle position and with periods at several different airspeed targets - e.g. see attached plot from a simulated flight. This can be done either in FBWB mode using the throttle stick or in AUTO mode with DO_CHANGE_SPEED mission items - see attached example mission file (don’t load this directly as it’s in Australia!).
After the flight the log items PLRN.CD0 and PLRN.B show the convergence of the estimates, and the parameters SOAR_POLAR_CD0 and SOAR_POLAR_B will be updated to the final values.
CMAC-glidepolar.txt (1.1 KB)
I’m keen to see any logs involving this feature - the firmware builds are here (edited), let me know if you need a different board built.
Sam
Hi Sam,
That seems to be very helpful. Could you build a FW for MatekF405-Wing pls?
I would like to test it if the stormy weather will change. Currently the RC-airfields are closed, but allone “on the green lawn” flying is allowed here.
Regards
Willy
Hi Sam, just a simple question, I am a bit confused about which board supports auto-Soaring function:
@Quaxwilly I’ve built for the Matek boards and updated the link in my last post, hope you get better weather!
@ton999 Soaring is supported on all boards except the following:
Sam
Ok.Tks. Sam. I like to try this function with Matek F765 or Holybro Pixhawk…
Hello
I’ve done several test for soaring. But I’m not able to get a stable glide.
I have increased PTCH2SRV_IMAX to 4000 and TECS_INTEG_GAIN to 0.3.
I have set SOAR_VSPEED to a large number 50, switched the SOAR_ENABLE_CH > 1700 and set flight mode to FBWB. The plane always tries to maintain the altitude, keeps the nose up until it is too slow, thereafter the nose goes down and everything begins again.
Which parameters are wrong?
Thanks for your help!
Hi Manauel,
Difficult to say, do you have a SD card log?
Thanks for your answer!
I’ve just rereaded the autotuning procedure.
Maybee my STAB_PITCH_DOWN parameter is too low? At the moment it is 2.
I try to increase it.
I will post a SD card log after next flight.
hello again!
Demanded Airspeed is 6 m/s. I think this is too slow!
ARSPD_FBW_MIN is 6 m/s. Should I increase this value?
Hi Manauel, can you post the log?
Hello Samuel
Thanks for your help!!
Here is the logfile:
Soaring active is from 14:29:
