Can’t load firmware for SV video viewer 2.0. The sv viewer requires a wifi connection to download the firmware. Won’t use in phone hi-speed data. Is there a workaround without using wifi?
If you look at the section about uploading via SD card. I think this will work on a journey too.
http://ardupilot.org/copter/docs/skyrocket-software.html
Uploading using the SD card
powerdown the drone and remove the SD card from the back of the skyviper and insert into your PC (an SD card adapter may be required)
copy the firmware into the top directory of the SD card and then rename it to “flight_fw.abin”
place the sd card back into the drone and power up the vehicle
after about a minute the LEDs should flash and the vehicle should reconnect to the transmitter
