Skid steer quick turn issue
Hi;
How can I slow down the rotation speed around itself when using a skid steer vehicle. I can slow down the driving speed by turning down the Throttle Max setting on the Basic Tuning screen, but I could not find how to slow down the rotation speed. I would like your help in this regard.
Theres a turn rate parameter in degrees per second
Wp_pivot_rate
Its a good idea regardless of which fw you use to read all the docs for your fw including all the descriptions of all the parameters.
Hi;
Unfortunately, when I change Wp_pivot_rate setting up and down, there is not the slightest change in speed.
If you’re using MANUAL mode, that’s just the way it is. You’re commanding RC passthrough, and it’s taking your raw commands. Use ACRO or STEERING.
thanks yuri i will try acro or steering.
