I’m trying to compile ArduPlane for SITL simulation. I cloned the Github repo, used the Arch Linux install script to install packages for me (I use Arch, btw), and then ran ./waf configure --board sitl
, and then in ArduPlane/
, I ran sim_vehicle.py --osd --console --map
, and I ran into this error:
[476/902] Compiling libraries/AP_Terrain/TerrainIO.cpp
[477/902] Compiling libraries/AP_Torqeedo/AP_Torqeedo.cpp
../../libraries/AP_Soaring/AP_Soaring.cpp: In constructor ‘SoaringController::SoaringController(AP_TECS&, const AP_Vehicle::FixedWing&)’:
../../libraries/AP_Soaring/AP_Soaring.cpp:171:17: error: member ‘SoaringController::_polarParams’ is used uninitialized [-Werror=uninitialized]
171 | _speedToFly(_polarParams),
compilation terminated due to -Wfatal-errors.
cc1plus: some warnings being treated as errors
Waf: Leaving directory `/home/william/Documents/projects/uav/ardupilot/build/sitl'
Build failed
-> task in 'objs/AP_Soaring' failed (exit status 1):
{task 140696087162192: cxx AP_Soaring.cpp -> AP_Soaring.cpp.0.o}
(run with -v to display more information)
SIM_VEHICLE: Build failed
SIM_VEHICLE: Killing tasks
That’s not the whole output of the command; it’s just where the error happens. I can post the whole output, if needed. A friend of mine who has done the same some days or weeks ago on a similar system running Manjaro has not run into this error.
