When I launch SITL to test the antenna tracker, as soon as I click on the simulated quad, the quad appears in Australia (Somebody said it is Tridge’s house). Even though I set the TRACKER HOME at BC in Canada by dragging the green tear drop icon on the mpa, or by right clicking at my home location in BC , the QUAD still appears in Australia. See attached.
Connect AT controller
to PC Mission Planner via telemetry radio. Don’t click “connect”
Click “Simulation
Choose vehicle
Top right hand corner
changes from “connect” to “disconnect”, and COM port changes
to “TCP”
Press “Ctrl –F”
. If “temp” windows does not pop up, drag the whole windows
up/down a bit, then Press “Ctrl-F” again, “Temp” windows
will pop up immediately. Otherwise, you have to wait for few minutes
before trying to press “Ctrl-F”.
Click “Mavlink”.
“Serial output -Mavlink” windows pops up.
Select COM port and
set speed to 57600, make sure the tracker has booted, then click
“Connect”, followed by long beep.
Quad appears on AT
screen
Wait
for 2-3 seconds, then click “Arm and takeoff”
Then select
whatever mode to fly in “Actions” tab under HUD.
But from time to time, when I launch SITL, the copter appears over in Australia (step 8 above not true), and it takes me tons of effort to position it back to Canada. After that, I do not know what I did to succeed because I tried many many different ways.
I used the set home button many times in MP in VARIOUS STEPS in my above procedure, but it did not work out. If you have time, can you please try to do it once and tell me the steps ?
On the simulation screen, before you choose your vehicle, zoom out on the map, look for the green home icon and grab it with the mouse and drag it to your intended home position.
