I’m trying to setup SITL using network connection between mavproxy.py and ArduCopter.elf. Is this possible?
When i look at the diagram on http://dev.ardupilot.com/wiki/sitl-simulator-software-in-the-loop/#sitl_architecture then i would say YES, because it’s a normal TCP connection.
I have arducopter running in cygwin on my windows 7 system, and want to run mavproxy on raspberry pi which is connected with a direct lan cable (ip setup is configured and working fine).
What i find strange is that the –master option of mavproxy states that in case of IP it must be the local computer’s IP address. So you can never connect it to a remote system (to control it) ?? I thought that was the basic idea of a GCS ?
Thanks for any insight.
Ruud
