Hello!
I am attempting to simulate an aircraft and feed the data to an Arduino with an Ethernet shield. I have the UDP packets coming across and getting what the Arduino is attempting to parse as Mavlink messages but I think something in my assumptions is wrong as the messages it parses look like bad data.
To send the Mavlink Messages I am using “output add” in SITL. This I know is how you connect new ground stations but I assumed the new ground stations just connected via Mavlink messages? Is there a way to send just the mavlink messages over UDP with SITL? Are the ground stations communicating in a more complex way then just mavlink messages?
Got it! To answer my own question… NO, adding additional GCS in SITL uses Mavlink protocol like serial port or anything else. I now have an Arduino taking in Mavlink messages from SITL running on a computer. the hardware used is an Arduino mega with ethernet shield.
UDPReceiveMavlinkMessages
This sketch receives UDP Mavlink Messages and has a few examples of parced messages. you can easily add whatever messages you want to parse to the SWITCH case
Created 2/29/2024
by Tristan Williams
#include "mavlink.h"
#include <Ethernet.h>
#include <EthernetUdp.h>
//rates from Pixhawk Mavlink Messages
double yaw_rate;
double roll_rate;
double pitch_rate;
//attitude from Pixhawk Mavlink Messages
double yaw;
double roll;
double pitch;
//enable to print status info to SERIAL
bool DEBUG = true;
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 177);
unsigned int localPort = 8888; // local port to listen on
// buffers for receiving and sending data
char packetBuffer[2048]; // buffer to hold incoming packet,
char ReplyBuffer[] = "acknowledged"; // a string to send back
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
void setup() {
// You can use Ethernet.init(pin) to configure the CS pin
Ethernet.init(10); // Most Arduino shields
// start the Ethernet
Ethernet.begin(mac, ip);
// Open serial communications and wait for port to open:
Serial.begin(9600);
// Check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
while (true) {
delay(1); // do nothing, no point running without Ethernet hardware
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
Serial.print("My IP address: ");
Serial.println(Ethernet.localIP());
// start UDP
Udp.begin(localPort);
void loop() {
// if there's data available, read a packet
int packetSize = Udp.parsePacket();
if (packetSize) {
IPAddress remote = Udp.remoteIP();
// read the packet into packetBuffer
Udp.read(packetBuffer, 2048);
mavlink_message_t message;
mavlink_status_t status;
for (int i = 0; i < packetSize; ++i) {
if (mavlink_parse_char(MAVLINK_COMM_0, packetBuffer[i], &message, &status) == 1) {
//use this to see what all Message IDs are coming across
// Serial.print("Received message:");
// Serial.println(message.msgid);
switch(message.msgid) {
case MAVLINK_MSG_ID_RAW_IMU: // #105 highres IMU / Check scaled IMU for acutal value readings
mavlink_raw_imu_t raw_imu;
mavlink_msg_raw_imu_decode(&message, &raw_imu);
roll_rate = raw_imu.xgyro;
yaw_rate = raw_imu.zgyro;
pitch_rate = raw_imu.ygyro;
//DEBUG
if (DEBUG){
Serial.print(1);
Serial.print(",");
Serial.print(roll_rate);
Serial.print(", ");
Serial.print(pitch_rate);
Serial.print(", ");
Serial.print(yaw_rate);
Serial.println("");
break;
case MAVLINK_MSG_ID_ATTITUDE: // #30 ATTITUDE
mavlink_attitude_t attitude;
mavlink_msg_attitude_decode(&message, &attitude);
roll = attitude.roll; // rad (-pi..+pi)
pitch = attitude.pitch; // rad (-pi..+pi)
yaw = attitude.yaw;
//DEBUG
if(DEBUG){
Serial.print(roll);
Serial.print(", ");
Serial.print(pitch);
Serial.print(", ");
Serial.print(yaw);
Serial.println("");
break;
// send a reply to the IP address and port that sent us the packet we received
Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
Udp.write(ReplyBuffer);
Udp.endPacket();
delay(10);
