Has anyone successfully run SITL on Ubuntu 16.04, I’ve tried everything I’ve found on the internet but i still end up getting errors when running sim_vehicle.py
here is output of sim_vehicle.py -w
SIM_VEHICLE: Start
SIM_VEHICLE: Killing tasks
SIM_VEHICLE: Starting up at -35.363261,149.165230,584,353 (CMAC)
SIM_VEHICLE: WAF build
SIM_VEHICLE: Configure waf
SIM_VEHICLE: "/home/mh/ws/ardu/ardupilot/modules/waf/waf-light" "configure" "--board" "sitl"
Traceback (most recent call last):
File "/home/mh/ws/ardu/ardupilot/Tools/autotest/sim_vehicle.py", line 973, in <module>
do_build(vehicle_dir, cmd_opts, frame_infos)
File "/home/mh/ws/ardu/ardupilot/Tools/autotest/sim_vehicle.py", line 371, in do_build
return do_build_waf(opts, frame_options)
File "/home/mh/ws/ardu/ardupilot/Tools/autotest/sim_vehicle.py", line 323, in do_build_waf
run_cmd_blocking("Configure waf", cmd_configure, check=True)
File "/home/mh/ws/ardu/ardupilot/Tools/autotest/sim_vehicle.py", line 450, in run_cmd_blocking
p = subprocess.Popen(cmd, **kw)
File "/usr/lib/python2.7/subprocess.py", line 711, in __init__
errread, errwrite)
File "/usr/lib/python2.7/subprocess.py", line 1343, in _execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
sim_vehicle.py
Have you done:
git submodules update --init --recursive
waf distclean
'distclean' finished successfully (0.044s)
waf configure
Setting top to : /home/mh/ws/ardupilot/ArduCopter
Setting out to : /home/mh/ws/ardupilot/ArduCopter/build
No function 'configure' defined in /home/mh/ws/ardupilot/ArduCopter/wscript
waf copter
No function 'copter' defined in /home/mh/ws/ardupilot/ArduCopter/wscript
Setting out to : /home/mh/ws/ardupilot/build
Autoconfiguration : enabled
Setting board to : sitl
Checking for 'g++' (C++ compiler) : /usr/lib/ccache/g++
Checking for 'gcc' (C compiler) : /usr/lib/ccache/gcc
Checking for need to link with librt : not necessary
Checking for HAVE_CMATH_ISFINITE : yes
Checking for HAVE_CMATH_ISINF : yes
Checking for HAVE_CMATH_ISNAN : yes
Checking for NEED_CMATH_ISFINITE_STD_NAMESPACE : yes
Checking for NEED_CMATH_ISINF_STD_NAMESPACE : yes
Checking for NEED_CMATH_ISNAN_STD_NAMESPACE : yes
Checking for header endian.h : yes
Checking for header byteswap.h : yes
Could not load the Waf tool 'clang_compilation_database' from ['Tools/ardupilotwaf/', '/home/mh/Downloads/.waf-2.0.4-91d6a4e5781350f87eb0a75b95b84884', '/home/mh/Downloads', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-x86_64-linux-gnu', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/home/mh/.local/lib/python2.7/site-packages', '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PILcompat', '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/python2.7/dist-packages/ubuntu-sso-client', '/usr/lib/python2.7/dist-packages/wx-3.0-gtk2']
No module named clang_compilation_database
(complete log in /home/mh/ws/ardupilot/build/config.log)
and the output of the waf copter is The project was not configured
