Hello:
I have various questions about mission planner sitl 1.3.35 running on windows 7. The first:
The simulation vehicle always starts on lng-214,74… GPS position. The GPS latitude is the same that I put at first in the map, and if a change the home position, latitude change too, but lng is always the same,-214,…
It happens on copter, plane, rover and quad of sitl. On model building msdos command window the starting model coordinates appears correctly.
The second question is about integrated simulator. I remember that in aold version of mission planner, when you starts the simulation, a new window with a simulated quad appears, and you see quad movements too.
Now, you need and external simulator for vehicles or mission planner has one integrated? I read something about jsbsim, but it looks that is only for buld mathematics model plane.
If I need and external simulator, how I can set up. The wiki instructions are incomplete. There is not enough information about sitl using mission planner on windows.
What about this?
Thanks in advance
